NoInterstates!
Help!
I am new to the forum, and so far am very impressed. I wanted to run some troubles I am having with our truck by you all. I have been chasing sparks around for almost a year, and am not having much luck as well as running out of ideas.
Symptoms are as follows;
Starting, Glows cycle fine, turns over quick and will fire and rev up to 1000, maybe 1200 RPM real quick then immediately die. When you turn it over, there is white smoke, smells like unburnt diesel.
Idle, The only way to get it to idle is to give it just a little throttle when it does fire. If you're lucky it comes into a ROUGH idle fluctuating between 800-1100 RPM. At this point, there is a lot of white smoke, smells like unburn diesel, and by a lot I mean my neighbors don't like me or my truck much anymore.
There are no codes.
I have changed the PMD with a brand new one from Dipaco. Remote mounted it with a SSdiesel PMD cooler. Checked all the grounds, tightened them. Ohmed from batteries to body to frame all very good. Changed battery cables. Put brand new injectors in(OEM Stanadyne ones.) Changed the ECM(kept the same chip). Changed the Crank Position Sensor, Coolant Temp Sensor, and the MAP/Boost Pressure Sensor. Not one of these things even made a slight difference. The exact same problem has persisted.
I was looking for your thoughts on this as fellow owners. Thank you all for your time and hope to see you on the road.
Take care
There are no codes.
Take care
