Detroit Dan
Changed it yesterday, didn't see anything horribly wrong with the old sending unit, it had a little rust on the tube but nothing that looked rotted through. The metal tub from the return line to the top of the unit was loose, but that shouldnt affect anything on the return side. I did also find a length of steel tube that was kind of rusty going toward the lp, plus the metal crimps that went from the rubber hose to the fitting that connects to the sending unit were rusty too. I ended up replacing the whole length of line with 5/16 rubber fuel line. I think my fuel gauge was screwy too, it seems a little more steady now.
I've only put about 5 miles on it so far, but it seems good. Running smooth with no hesitation or stumbling. Fuel pressure is 4-6 driving around at just off-idle, WOT its about 2-3ish. Havent been able to get it down to zero, but I also havent had room or time to get it up over 60 mph. I dont even have enough fuel to test it out, I put 5 gallons in it and that has to last me until payday, so no WOT runs. The couple short bursts I did felt pretty good, little blacker and heavier smoke than the greyish I was getting before. Can't say as to seat of the pants if its as great as it was that one time, but it is at least fixed and not falling down anymore.
