I see a lip on the outside edge of the valve, if you're not going to pay a shop for a valve job just clean and run as is...
I’d use the green plastigauge and see if you have .002” clearance.changing the subject and moving to the block. bearings have been a question on my mind. I have not pulled any of the main caps or rod caps yet. I know I will need to pull the rear main cap to get at the rear main seal, but as I inspect them, will I need to get some plasti-gauge to check them if they look good still? if so, which one do I need and what is acceptable and not for these old 6.2's
I assume all of those bolts will get re-used and get torqued and re-torqued as they are being checked with plasti-gauge. if not, that would be an expensive bolt replacement as I pull them and use the stuff to check clearances.
I was thinking about this mainly because if I can't get the upper portion of the rear main seal out, I will end up having to pull the crank out to get it out.
You need to look again at bearing clearance, keep bearing clearance at .0025-.0030 inch max....I found these two links that were originally posted by @WarWagon on a different thread. they have since disappeared from the web, but I managed to find them recorded on the wayback machine.
Here is the thread I found them on.
There is always a lot of chatter about the bearing and piston clearances on these engines.
These are metric engines and everything on them, save a couple things like the bellhousing bolt holes on the pre 96 stuff is metric.
The specs book all call out the clearances in MM.
This is not a big issue, but here in the States, we are used to measuring in Inches.
Here are some good hard numbers that you can take to the bank.
Piston clearance
Cylinders 1,2,3,4,5,6 can be set at .004" and work very well
Cylinders 7 & 8 run a tad hotter and will be very happy at aroound .0045"
The book...
- Missy Good Wench
- Forum: 6.2 and 6.5 Technical Reference Library
It seems the clearances for the mains are 0.045 - 0.083 for all except for #5 which is 0.055 - 0.093
And for the rods shows 0.045 - 0.100
New valves are best but you’d still need to get the seats reground to match the angle of the new valves.would it be better installing new valves? never done this before. I'm not wanting to send them to the machine shop if at all possible
