Husker6.5
I would still want to build something stout to protect the bottom edge of that radiator from contact.
Thanks! I'm stoked with how it's turning out.Lookin good!
Thanks man!That is looking awesome!
Thanks! Yeah it took a bit, but now you guys can see what I was seeing in my brain.That's good and what I was thinking when I mentioned using the stock air dam . Flows much better and looks all tied in . Makes the cooler look like it belongs there and not just hanging out in the wind .
As a bonus , you could put some rings along the bottom of the dam and add a section for a snow plow . Went to WMU back in the late 70's and we had some good snow storms .
Spiffy! What you need to do is paint shark's teeth along the air dam and around the radiator housing so it looks like a P-40 Warhawk!
Thanks guys!Looking good Nate
The bottom of the radiator surround has a 1/4" plate welded to it and the surround itself is 3/16" thick. So, the surround itself is strong enough, but it's only as strong as the weakest link....which is the bumper itself, so i think I will make some struts that go from the radiator surround to the frame to add that additional strength.I would still want to build something stout to protect the bottom edge of that radiator from contact.
