My tranny is working pretty good,but not quite like I want it to. First of all the converter will stall up to 3000 in 3rd or 2nd with lock up turned off. It will stall 2000 rpm,brake torquing. If I lockup the converter the same time as shifting to second ,the converter slips a lot,and line psi drops from 220-120 psi. I did get the converter to slip at 190 psi when lugging in 3rd. Do I need a triple disc converter,and why is the stock stall speed so high ? If I don't shift or lock up the converter under full power,it works fine,and can occasionally chirp second gear. I need a better converter. I might just get the local converter shop to build one,that way I can get them to make adjustments ,If it don't work on the first try.
