My 2005 Yukon XL
Nothing quite like holding the mic next to a speaker on the “good part” of a song or reminding another driver to pay attention to the road. I would ever rile up my dogs with it everyday when I get home either 🤣. There’s just something about country music that sounds better on a pa when working near the truck in a field…
I need a new cb & new speaker. A rock from a tire cracked my housing and it never sounded right. I just never did mount one in the hummer yet. What’s wrong with me?!
Got the back brakes pulled apart and cleaned up/regreased.
Fronts really need new rotors, the junkyard eBay ones barley lasted 1 year. Also trying to get new Viton o-rings for the catch can. Im having issues lately on start woth a puff of smoke. Common issue with the PCV system i guess on these. I really need to pull the drivers valve cover and inspect drain ports in the PCV system.
Been having a issue on cold starts. Puff of white/blue smoke. Definitely smells of oil. It all started when I did the new steering gear.
My hypothesis is my PCV system has an issue, allowing oil into the intake. Thus burning it off mostly noticeable on starts. I guess its common on this truck, and there are updated valve covers to remedy this. Ultimately I need to see what version cover is on there. But looking down the throat confirms oil is getting in there.
I had the front of the truck jacked to the moon to help bleed the steering system, since then I've been having this issue that is getting a little better day by day. But it leads me to getting the catch can installed ASAP until I have time to peel off the valve cover. Im trying to find a new set of o-rings as the old ones disintegrated.
What a mess. The OEM drain ports were all plugged up.20260321_135958.jpg20260321_140037.jpg20260321_140011.jpg20260321_140026.jpg20260321_140137.jpg20260321_151901.jpg20260321_152115.jpg
Its not perfectly clean, but its friggin in the 30s out, so I wasnt going for perfection. I mighta gonna aggressive on the drain holes.
I need to do the passenger side too just for the gaskets sake. But I ripped a bolt grommet on drivers side install leaving me short now.
Spent more time screwing with the catch can. Got the proper 3/8s fittings on order. I also ordered some new O-Rings from UPR, but i am honestly hesitant they will be right. I found a 2-1/8" @ 1/16" Viton rings i might try.also found a bunch of 3/8 fuel line in my arsenal to plumb.
Got the catch can in. Not 100% on routing and the magnitude of zip ties, but this location seems the best for overall serviceability. And its in service for the time being.
The Amazon o rings are still a little big, but close!
