swinters
Wreckers are great, their versatility is only limited by your imagination haha. The fuel was turned up in my m816 before I got it and it has some pep to it for a 40,000+ lb rig with only 250hp hahaha. Planning to install a turbo next year to help out, maybe test out a hx55 since it will spool early to cover the 800rpm gap between 3rd and 4th gear. Swap to a Eaton/Fuller RTOO series transmission would be a great upgrade.
When you put the turbo on, make sure that, if your 250 is one with vents between the intake and the crankcase, you block them. When you pull the intake manifold you might see in each port that there's a hole drilled that ports bypassed combustion gasses from the crankcase into the intake. Most Army engines are threaded and plugged, or there's just a boss there in the casting, but there are a bunch out there that are open. When you put a turbo on and those holes are open it pressurizes the crankcase and blows oil past the seals and fun stuff like that. If they're open and not threaded, just run a tap in the hole and Loctite a plug in it.
On the fifth wheel, we had a dolly in the shop like the trucking companies use when pulling doubles. We had to modify it to lengthen the frame of the dolly to move the fifth wheel back so that a box van would clear the boom but that was the only thing we had to do to use it. Our aircraft recovery section had the M819 Wrecker, which has a fifth wheel for dragging a flatbed. Not as robust and versatile as an M816 though.
