Small Update.
As I mentioned earlier, I am not at all thrilled with these stainless M8 x 1.25 threaded inserts (about $10 for six) but, they served the purpose of threading into the M10 x 1.5 Heli Coils I mistakenly used. I just don't think I could trust them to torque even to just the 17Flbs called for by the shop manual.
Likewise, I found the inserts from the Sennmon kit lacking in their feel of durability and would have prefered to use a carbon steel sert from either EZ-Lock or Timesert. Especially with the spare extrude honed lower intake I need a bolt hole 'foot' repaired or, a future replacement lower intake should I go that route. I pre-drilled and tapped this spare intake waiting for the longer serts to arrive which should be tomorrow.
As a refresher, The Sennmonn kit is a 'Time-Sert' knock off with the OD threaded at M10 x 1.25.
I decided against the EZ-Lock kits as they need the holes drilled out M12 for the 450-8 kit or 1/2"-13 for the 650-8 Kit.
I had mentioned that in hind sight I'd preferred to have used the carbon steel Time-Sert system but, pricy and I couldn't nail down the O.D. and thread pitch of their M8 serts. Well, I did some doom scrolling last night and discovered a user comment that listed the M8 inserts P/n 1812 as having M10 x 1.25 O.D. BINGO. Order just the serts and use the already purchased Sennmonn installation kit to do the job.
So, the cheaper feeling Sennmonn additional serts (14mm and 16mm long) will go back and cover the cost of the carbon steel Time-Serts arriving in two days.
Maybe I'll get a replacement intake for Father's Day? If so, I'll just drill it out and beef up the holes with these Serts from the git-go.
