Lower Intake Thread Repair Solutions.
Did that with the first intake. Did a lot of cutting on the upper half too trying to "improve" air flow inside. Still had to have the EGR on top since it is all open to atmosphere otherwise. Funny story (in hindsight) about that involving an SSDiesel 1st run 'Cold Air Intake Filter. I was fortunate to have found a set of intake gaskets that had the EGR ports blocked off. Haven't seen that type since.
Aluminum Spacer? Not a bad idea. I had hoped to have a chunk left over from the milling of my intake's spacer but, I gave all the scrap to the machinist who did the work. I'm going to leave the technique up to Chris.
Notifications tell me Amazon truck is just a few stops away. Time to get this Rube Goldberg repaired intake I've cobble together finished and the truck moved so I can get the pretty car in the garage before this new storm hits in a couple of hours.
This new pretty car statement.
I have a lower intake with an upper intake bolt hole busted out.
I will, someday, get out the aluminum arc rod that I use, and the oxy/acetylene torch, knock off a fair amount of the flux from the rod and play with building that bolt flange back out then drilling and tapping new threads through it, just to see if I’ve got enough technique to make it work. 🤷😹
Pictures of a butchered out upper and lower intake? Or do you want to see the pictures of the spacer and its morphing through development...from idea and concept, through wooden mock ups and a rough cut out by a local machinist, to a CNC'd piece that was once anodized, sorry, Purple?
The butchered unit didn't get pictures but, the spacer development was a 6 page thread. Some of the pictures are small but, you can zoom as desired. A lot of people from back then aren't here anymore. Just AKDiesel Driver I think is still active on the forums.
https://www.thetruckstop.us/forum/threads/intake-mod-other-project-or-two-and-finally-the-att.25488/
Hard to believe it's been almost 16 years ago.
Wait, I remember this (still scratching my head).
No, this portion of Your statement from that previous posting.
We would like to see what that pretty car looks like. 😹😹😹
A pretty car it is too.
Thank You for sharing, upon Your infirmation, seems a good one to put on the avoidance list.
One time, a V6 Audi in the pissant, oooops, passant. BILs car, cam shaft seal leaks.
That shore makes a horrible noise when them chain tensioners dont pump up quick enough, makes for poor horse power in the aftermath too. 🫣😖😬😹😹😹😹
Small Update.
As I mentioned earlier, I am not at all thrilled with these stainless M8 x 1.25 threaded inserts (about $10 for six) but, they served the purpose of threading into the M10 x 1.5 Heli Coils I mistakenly used. I just don't think I could trust them to torque even to just the 17Flbs called for by the shop manual.
Likewise, I found the inserts from the Sennmon kit lacking in their feel of durability and would have prefered to use a carbon steel sert from either EZ-Lock or Timesert. Especially with the spare extrude honed lower intake I need a bolt hole 'foot' repaired or, a future replacement lower intake should I go that route. I pre-drilled and tapped this spare intake waiting for the longer serts to arrive which should be tomorrow.
As a refresher, The Sennmonn kit is a 'Time-Sert' knock off with the OD threaded at M10 x 1.25.
I decided against the EZ-Lock kits as they need the holes drilled out M12 for the 450-8 kit or 1/2"-13 for the 650-8 Kit.
I had mentioned that in hind sight I'd preferred to have used the carbon steel Time-Sert system but, pricy and I couldn't nail down the O.D. and thread pitch of their M8 serts. Well, I did some doom scrolling last night and discovered a user comment that listed the M8 inserts P/n 1812 as having M10 x 1.25 O.D. BINGO. Order just the serts and use the already purchased Sennmonn installation kit to do the job.
So, the cheaper feeling Sennmonn additional serts (14mm and 16mm long) will go back and cover the cost of the carbon steel Time-Serts arriving in two days.
Maybe I'll get a replacement intake for Father's Day? If so, I'll just drill it out and beef up the holes with these Serts from the git-go.
That nice intake manifold is back up for sale on that facebook group.
IIRC Forsyth and surrounding area.
They had dropped the price to $80.00 but then I had to take the one cat to the vet for the doctoring and that knocked the crap out of the spare funds I had so I notified them I’d have to pass on it.
Which Facebook group?
Market Place.
Offer the guy $150 for both. No way he gets $180 each, especially for local pick-up. Just not that many 6.5s out there. I will send you a check. One will go to Paveltolz so I can shut down his thread. My wife can come pick them up sometime during the Summer. By then I should have the heads pulled on the old 506 6.5 and she can bring those to you.
"Shut down [my] thread." Now my feeling are hurt. sniff
I appreciate the offered gift but, please, keep the "F" intake for personal us and use pieces of the "S" intake to repair the broken one.
I'll be getting my spare intake repaired next week when I visit Chris and, of course, I'll be sure to post updates on this thread.
Thinking about intakes... got me to wondering about the non-turbo intake. they are taller and the runners aren't as sharp of a bend going out to the ports on the heads, I wonder if they would have better flow if a hat was designed for them to seal up for a turbo. Just thinking out loud!
