Nick 6.5
So I'm doing a lb7 duramax swap. It's basically done besides minor wiring, driveshafts and some other small things. But I had a dead pedal. P1287. P1278. P1125. P1639. I had the pedal extension harness made by a company back east and it is mirrored to the pedal connector.
App sensor 1 reads 4.96v and does not change with throttle input on pedal.
App sensor 2 reads 1.88v and drops to .63v at full throttle.
App sensor 3 reads .06v amd does not change with throttle input. And app indicated angle percent stays at 0
I switched wires e and j on the connector
With the wires switched App sensor 1 gets .45v at neutral and 3.53v at full throttle
App sensor 2 is at 1.88v at neutral and .61v at full throttle
App sensor 3 is at 4.12v at neutral and 2.25v at full throttle.
App indicated angle stays at 0 at all times no matter what. I can't figure out what the hell is going on. I've tested the pedal and it is good. I've also used a second pedal with no change. Also have ohmed out the wires the Ecm and it's good as well. I'm starting to think its the ecm?? Any input from the masters here would be extremely helpful!!
