illville
- Messages
- 56
- Reaction score
- 0
Great pics; that is a seriously nice looking rig!
Thanks, it sould look better once i get the HX40WII in there
Dont know, i just ordered the turbo, if this intake doesnt work out though ill give you first crack at it.
Past posts have shown that the waste gate will not clear a factory box not sure, just wouldn't want that nice AFE intake cut up.![]()
Ya, I was hoping to run the spring adjustable boost controller to solve that but we'll see, as much as i paid for the AFE i would hate to hack any part of it up.
Well for starters you have to have a boost gauge this way you can dial in the boost.
With the spring waste gate the exhaust back pressure over comes the spring and compresses it. I would think that is most reliable, no parts to wear out or diaphram to dry out or a splitting hose like on the boost actuated style
Yes true but its also nice not having smoke on accel or on shifts and I'm not a fan of lag. I have run non gated in the past and I didn't like how it worked in my area
I don't have back pressure numbers myself, I have yet to hook up a gauge for drive pressure.
What turbo were you running when you had the non gated turbo, must have been a little large? Were you running it on the truck you have now? Drive pressure numbers would be nice if they were available, I have not seen any hard numbers posted yet.
I was running a banks on my truck that I still drive now. IIRC, the turbine housing was a/r 1.00 and the compressor was an a/r .60 it did feel better then the gm turbo. But boost didn't come on till around 1800RPMs.
Was that the turbo from the original Banks stinger kit for the 6.2s
Even the prime proponent of the HX had to tweak a program to get best out of the HX
Tim writ:
Is there actually a specific tune for the HX? Sorry if I missed that tid bit. I know ATT has a specific tune.
Right now I run the Heath GL4 tune and know that there is more potential in the tune for the HX. Honestly I was just thinking about getting the ATT tune which would be close IMO.
Also to add. I run the stock HX with the 20 PSI valve, no problems at about 15K. But I drive easy, very rarely over 14PSI. And when towing I just regulate by left foot for Pyro and Boost.
I'm headed to Orlando next week with the trailer, so I should bring back some good MPG numbers when towing on the HX.
