Once you got all the air out and it running smooth, it seems fine. you might have a bad motor mount though. I will let others chime in. easy way to check is to put it into drive, hold the brake and lightly goose the throttle. watch to see if the motor lifts on one side. then do the same thing in reverse.
Loose bolts as in the ones holding the mount clam shell to the frame or the single through bolt? if it was the single through bolt. do the same thing again that I mentioned on seeing how much the engine moves when in gear with a blip of the throttle. you can put a little more load on it, see if you feel and see the motor lift and fall back.
Bad photo. But its the one that attached to the frame sir, it was this mount tho
I held the nut with a wrench and tightened the bolt with a socket, it worked, and whenever I go from D to R, I no longer feel such a force, heck its smoother now idling.
Very off topic (I did the peep the mounts btw, seemed alright, motor is visibly less shaky now)
How would you all recommend i go about aligning the doors? Per the photos, its obvious there is sagging, but, the doors themselves (mainly at the bottom) seperate too much from the body.
Ive heard about washers/shims, would that work for door alignment? Id just like to have them symmetrical and have the door close easier than it already does.
(Attatched under the photos will be videos of how both the doors close.)
20260414_113541.jpg20260414_113548.jpg20260414_113551.jpg20260414_113555.jpg20260414_113600.jpg
First photos are from the driver side^
20260414_113541.jpg20260414_113548.jpg20260414_113551.jpg20260414_113555.jpg20260414_113600.jpg20260414_113742.jpg20260414_113752.jpg20260414_113800.jpg20260414_113803.jpg20260414_113810.jpg
Passenger side^
Video:
I believe on your rig, the hinges can be shimmed, they also make a tool that attaches to the striker and latch to help align the door too. I will let others chime in on that part.
Shoot if thats a thing someone do tell, ill actually cop that and the shims.
Has anyone ever aligned their door via shims here?
It could also be that the door pillar is tweaked too. when the door is closed, how are the body lines at the front fender? is the bottom also pushed out there as well?
The striker pin is that bolt in your pictures that the door latch hooks onto when closed. Barely loosen it, and there is a captured nut behind it and large washers on both sides. It goes through a fairly large hole. By moving it up/down/ in / out you can adjust where the latch area of the door fits when closed.
The hinges are adjustable as mentioned. You can move the top & bottom hinge in and out to get the front of the door to align there. Most folks start at the hinges. Then when the front seem is good the adjust the striker pin.
Basically you adjust the door to fender at the hinges & latch is for the center of thr door. Beyond that- is a bend door shell or bent pillars. The window frame commonly gets bent inward and need simply small amounts of force to bend it back- they get bent by people using it to close the door by pulling on it.
