Opinion* dear Lord.Could use an option.
Does it seem like my motor shakes a little too much?
Bad photo. But its the one that attached to the frame sir, it was this mount thoLoose bolts as in the ones holding the mount clam shell to the frame or the single through bolt? if it was the single through bolt. do the same thing again that I mentioned on seeing how much the engine moves when in gear with a blip of the throttle. you can put a little more load on it, see if you feel and see the motor lift and fall back.
