I was going off this for proper starting techniqueThe two wires making the connection at the terminal is correct and stock.
You need to start recording that video on the clear line before the engine starts in the morning.
Fyi proper starting technique is push throttle pedal all the way to the floor once and then release before turning the key on.
Ah I seeYes the two green wires in your video.
The start procedure GM forgot to add from Stanandyne who made the ip…
Pedal to floor then release resets the external solenoid how it can sit at different positions on the stepping arm, and for the cruise on ones equipped. It also ensure throttle return to idle via springs- one of those exciting moments should it fail with the engine running moments to avoid.
Harbor freight has a real nice diesel engine compression test kit for not a lot of money. It comes in a case with aI am keeping this vehicle for the long run.
Im aware of how much new vehicles cost (not including insurance, etc). Therefore ill do anything MX wise to ensure it keeps on going.
Ideally, I would love to teardown and rebuild, but that won't happen for a very long time.
Until then, ill do the required MX stuff that I know I must do to ensure it keeps running, the longer this lasts the better. Even if I get out the Military, I plan on keeping it, ill gladly take it with me back to NYC
My friend has a diesel compression tester (454 burban bro) Ill see if he's down for said tests.Harbor freight has a real nice diesel engine compression test kit for not a lot of money. It comes in a case with aload of GP hole adapters.
If it was My wehicle, thats one of the tools I would have setting and ready.
Get one of those sets then run the compression test. Our curious minds is wanting to know them numbers.
Next up for a fairly inexpensive upgrade is that timing chain/sprocket set.
Not knowing the history on my old engine I pulled the timing cover, near a shock mode condition after seeing how much the chain had stretched, could nearly wrap it back onto itself around the Crank sprocket.
Also while it is removed, would cost some bucks but a Fluid Dampener from one of the sponsor sources would create a lot more longevity to Your crank shaft and engine.
Im content with that, well aware that unless I quite literally teardown and rebuild from ground up, it won't be "like new" (as new as it can be that is)Personally, I think you might need to except you have a 30+ year old motor, weak rings, slick cylinder walls, IP wore, among other things, until you go through the inside of the motor not much is going to change... Such is life...
