I was going off this for proper starting techniqueThe two wires making the connection at the terminal is correct and stock.
You need to start recording that video on the clear line before the engine starts in the morning.
Fyi proper starting technique is push throttle pedal all the way to the floor once and then release before turning the key on.
Ah I seeYes the two green wires in your video.
The start procedure GM forgot to add from Stanandyne who made the ip…
Pedal to floor then release resets the external solenoid how it can sit at different positions on the stepping arm, and for the cruise on ones equipped. It also ensure throttle return to idle via springs- one of those exciting moments should it fail with the engine running moments to avoid.
