Clean your ERG with an electronics spray cleaner. That fixed my problem.
I don't have a ERG on my truck, Nor a EGR.....truck runs pretty good, no idle issues, good mpg, no power loss, no hard starting, just a strong diesel smell and blueish/grey smoke at idle
Try loading your stock tune back in first and see if it still does it. If it clears it up, you can go back and adjust your fuel delivery below 800 RPMs.
I tried cleaning the MAF and that worked for a few days, I am back to smoking again. I could never get rid of the diesel smell tho....
when Idling at a intersection.....greyish/white smoke at idle, take off and blue smoke. Climbs hills without going into passing gear and idles pretty good. Balance rates are good. Fuel rail pressure not sure. maybe I will check it next....but I am sure it is the injectors. Looks like all I will get is 150k out of a set. :mad2:My balance rates are still within spec on mine, but I get ALOT of blue smoke just off idle. Problem started when I put in my injectors, plan on putting in a set of BOSCH ones to clear it up.
