Differential cover, gasket or RTV silicone?
Jorge6.5
Upstate New York
I got a new differential cover for my rear end. It came with a new gasket. Ive never used a gasket there before. Am I safe to just use the gasket alone or use the gasket with RTV? Should I just use RTV alone?
Thanks
I have always used grey RTV. Be careful to make sure and use RTV as regular silicone will break down with gear oil. Also a lot of the black RTV will not hold up to gear oil.
I've never gotten a gasket that fits properly before. I always just use RTV
Fixed it for you. RTV will always work. Most of the time I can't get a diff gasket that is the proper one. One of the few parts my parts store hasn't figured out.
I have used both with equal success, but i usually just use rtv.
If going that route, make sure your bolt holes in the cover aren't "dimpled". I put my covers on a flat anvil and then gently hammer them flat before reinstalling.
I'll usually blast and paint the exterior too, but thats optional depending on condition of your cover. I use engine enamel and bake it hard.
