CV Axle Seperation
On my most recent trip out to El Mirage for some more crew chief duties I hit an unexpected big dip in the road and, yeah, another roadside swap for a busted Half-Shaft, Driver's side. Was hoping to have it repaired before hitting El Mo but, long story short, parts weren't on the truck coming down from out of state with Chris. His buddy has a strip yard and got them for me but, still in the back of Chris' Duramax which is at the yard still waiting on an Engine & Transmission swap (previous road trip).
I got my hip rested up from the other chores I've been doing since I got home and last Thursday I went to a pick-a-part yard to get the parts myself. I got the passenger side carrier brace ok but wasn't able to get the driver's side part cut out of the donor truck with the grinder and cutting wheel. There was plenty of room to do the cutting but, there is also a lot of quite dry cheat grass under and around the vehicles and I didn't want a grinder generated spark to make me an unwanted customer.
Passenger Side Carrier Frame Brace.
Driver's side part I need to cut off to replace the one that was removed back in 2007 for dropping the front diff. for the suspension lift.
I need to cut along the red dotted line.
I went back the next day with a Sawzall/Jigsaw but, the metal was too tough for even a 'Heavy Metal' blade. "Have a plan B (C, D, E...) because plan A won't work" Ranger Patrolling Rulz.
While at the yard, I did find a differential skid plate that my truck doesn't have (if it ever did have one, I don't know/remember). I had to take it off the donor truck to get at the piece I needed to cut out and figured I'll want one when I get things put back up where they belong. There was also an aluminum splash plate on the donor so I grabbed that too. Everything was covered in a half inch layer from 32 years of grease, oil and dirt but, after a couple of hours of work scraping with putty knives, degreaser and pressure washing the pieces cleaned up pretty nice.
For correcting/restoring the driver's side differential carrier:
Upper is easy because nothing was cut. I'll remove the upper mounting bracket and, after removing the lower bolts, return the upper bolt through it's OEM location.
Aftermarket bracket to suspend the differential. The green arrow shows OEM Bolt Location. Red "X'd" bolt will be removed and the tab probably cut off so I can reweld things.
I figure I'll repurpose the drop kit's lower mounting bracket instead of waiting on weather or others. Remove the two bolts marked with a Red "X"
After determining how much of the aftermarket bracket to cut off, the Green marked OEM bolt go through the OEM location on the suspension and clamp things together so I can then well things back to the frame.
I'll have to recenter the bushings on the differential, of course, before finalizing anything.
At least I'll have my Father's Day gift to play tunes to help keep my head calm while muddling through all this. I've got the best wife.
The lesson learned, at least one of them here, is that these things are engineered the way they are for a good reason. Yeah, bean counters….got it. When you change things from their original design, there are other systems that will change that one isn’t suspecting or overly concerned about that can bite you in the wallet later. In my previous life, we called them ‘Second and Third order effects.’ Still do.
OEM suspension and drivetrain in this case from the suspension lift. Raise the ride height, lower the differential, insert different upper control arms, change drive angles, change suspension geometry and suffer accelerated tie rod, ball joint, pitman arm, idler arm wear and tear. Even the new cross-over pipe’s bung fitting for exhaust gas temperature gauge sensors is affected
Remove the lift kit but, as in my case, not completely because one doesn’t know what went on during the installation and, suffer even greater $$ costs and inconveniences.
Yes, if I’d done the lift myself…got it. But, I didn’t. To quote Otter from Animal House, ‘You [screwed] up. You trusted us.’
That’s life.
Now, to further attempt to unscrew things and get the differential back up where it was designed to be.
That’s life.
I glanced through the pics wondering how do you know where the original positions should be?
Honestly feel for ya. I would have given up long ago.
Seen this issue over the decades- many times people don’t understand why brand X vs brad Y costs more. Often it is the difference of actual engineering vs estimated design, and or the difference of R&D vs just making parts.
Factory is not always best. GmX turbo, factory exhaust, factory intake, factory glow plugs, the list goes on. I can’t say which lift kits were the good and bad ones. But I bought used gmt400 that were lifted& had friends with them who never had an issue.
I think either your’s was something designed wrong, installed wrong, frame tweaked somehow… idk.
I hope going back to everything stock fixes your issues.
As mentioned a few times: 3" Rough Country Lifts with the differential dropped, eliminated half-shaft stress issues but, are, apparently, notorious for destroying steering components as there's nothing included (at the time) to adjust for those angles. A fact I wasn't aware of and didn't know about until I experienced dynamic tie rod end failure on a sharp curve. The upper control arms are modified as well. Longer front shocks and different torsion bar keys complete the front side.
Not removing ALL of the Rough Country Lift components associated with the differential drop is what has been causing the issues with the half shafts.
Here's the factory vs. "Dropped" passenger side carrier brace. Red Circle denotes the differential.
Even easier to see the differences with them aligned at the mounting holes.
The old differential is dropped and the Rough Country Hardware is out.
I'll cut down the lower pumpkin adaptor and utilize it in securing the bottom. Mounting bolt through the lower control arm point as normal. Then weld it all up to ensure it's secure. Not all cut lines are noted yet.
Got the passenger side brace put in and the differential relocated to the correct height. Before that could happen though I had to adjust the differental’s upper and lower driver’s side mounting bushing. The differential had shifted towards the passenger side as a result of the CV shaft beating on things when coming apart. Couldn’t fully raise the diff because the pumpkin was hitting the oil pan. Got out the ball joint press kit and pushed the bushings over about 1/3”. That’s all they’d go but, the clearance is restored and it’s all back up where it belongs.
None of the bolts are fully tightened as I’m till messing with fabricating a replacement for the driver’s side lower brace.
I’m cutting down the drop brace to weld back in where the OEM one was cut off from the Lower Control Arm brace. Having to do some more fabricating as there isn’t enough clearance between the pumpkin and the LCA.
I originally planned on leaving the piece I’m holding attached but, there isn’t clearance between the LCA brace and the differential.
Once I finish fabricating things up I’ll torque all the bolts down to final 80lbs and next Wednesday I’ll go over to my old welding class room and borrow some time on a machine to weld it all up.
I’ll be glad when all this is finished…pipe dream.
Finished the Lower Bracket Fabrication and cleaned up the LCA surface for welding (fingers crossed for this Wednesday). Again, that hole you see in the LCA was put there for mounting the drop bracket.
You can see here how the lower mount lines up with the LCA.
Cut a guide line on the lower bracket and ground out a portion to allow a bolt to sorta brace things in the meantime until welding. I'll remove the bolt, finish the cut and then do the welding. Covered the bracket and the LCA surfaces in primer and bolted everything up.
I thought the pumpkin would still make contact with the Oil Pan but, after torquing things down, there's a weee bit of space now.
The front side of the LCA got beat up during the last half shaft fail and folded a bit of material over the bolt's head.
I got the air-chisel out and beat the fold back so the bolt head is accessible should that become necessary in the future.
Torqued everything down on the driver's side of the differential and will finish the the passenger side bolts and install new Half-Shafts on Monday with the expert help and supervision of my 13 and 10 year old Granddaughters. This should be fun.
In the meantime, Happy Father's Day to you all.
That is mighty close to the oil pan. I would keep an eye on the axle bushings and the motor mounts. a little bit of sag and you might see some rubbing action!
Thank you and BigT and Chris.
I agree as I woke up early this morning (3 am) thinking about the issue and, ultimately, I'm not happy with it either. There's over a half inch of adjustment available on the passenger side mount (which has oval holes). I plan to drop the whole thing, break out the ball joint puller/installer and use the 'big guns' to seat those bushings. If they won't adjust, I have another differential standing by 'for just such an emergency.'
