Paveltolz
Доверяй, но проверяй
Last week I had a CV axle pull out of the inner sleeve/hub. I had gone over a speed bump/ramp apparently too fast and the driver's side pulled out and wedged behind the inner sleeve. Needle bearings, etc. spread out for a while. Thanks to SS Force, we were able to get me on the road in no time but that was weird.
I've replaced the front differential as a complete unit along with the steering gear prior to November. Since then I've driven in 4 wheel drive many times with sharp (as possible) turns in city streets/parking lots. Driven the Pony Express for 60+ miles as well as 100+ miles of the Trans-continental RR bed with an additional 40 miles of spine rattling washboard dirt road. I've crawled around other dirt roads. I inadvertently aired the truck once earlier last fall too (oops). All with no issues.
Now the real mystery. Friday morning, coming out of 4 Wheel drive, 40 feet later I make a sharp right hand turn in a parking lot at 5mph and the new driver's side CV axle separated with the shaft coming out of the inner hub...again. :???:
No time to fix it, I have the truck schlepped home by AAA. Most humiliating but I had to be out of town so I've parked it until this coming weekend.
My front end lift is 6 years old, new bushing last winter. It's an El Ranchero or something another 3" tortion key lift with extended upper A arms. The lift has been turned down to preserve tie rods and, I thought, CV Half Shafts....:skep:
Any ideas cause I have to use this truck for some of my job stuff and, therefore, have to be able to trust it. If I can't make a turn in a parking lot without it busting up...
