I liked it too and I’ve missed it.
Yesterday I tried turning up the torsion bars and swapping in the 5100 series shocks. Of course, I discovered a couple of issues.
Torsion Bars. With the front end off the ground, the upper control arms are almost in contact with the frame mount that limits suspension travel. This is the same feature the bump stops are bolted to underneath. This is before adjusting the torsion bars. Adjusting the torsion bars to add lift while the wheels are off the ground causes the upper control arms to actually rest on this feature. With the truck on the ground, no contact but, turning up the keys is thwarted by the weight of the truck. Now I understand why the Rough Country’s control arms are needed as they are shaped to clear this obstacle.
Shocks. I know they went in to BigT’s suburban without issue but…
Here’s a side by side of the uncompressed 5100 and ‘OEM 4600’ off my truck. I’ve compressed the other 5100 to install it.
The compressed 5100 had about 2” of travel left to do any dampening once the truck is lowered. Keep in mind, with the truck set to stock ride height, the 4600 is 1/4 too SHORT to install. A slight push upwards on the lower control arm with a jack is needed to get the bolts through. Which I needed to do since the 5100 is too thick to fit clear the gap in the upper control arm. However, with the same jack pushing up on the lower control arm, there’s enough of a geometry change to give the needed clearance. I’ll just have to bottom out the 5100 to fit it in there meaning, no shock dampening once the truck is on the ground.
So, slight dilemma. Turn up the torsion bars and blow out the 4600 series shocks from over extension and perform an isometric stress on the upper control arms since they are pressed against the frame thingy (horn) while adding lift.
Shove the 5100’s in somehow and let them act as real ‘shocks’ to the body as they are near bottomed out.
Leave the truck ride height as is with the lower control arms resting on the bump stops and the 4600 shocks doing something…
In looking at the current Rough Country offering, the upper control arms different from what I got in 2007. These are forged to allow the clearance over the bump stop frame mount and not just a couple of steel tubes welded to a ball joint mount like the old units.
So, with these I can turn up the torsion bars to get the CV axel angles back to “normal”; get clearance over the frame horn/bump stop mount; fit the 5100 series shocks to have dampening; not have the truck resting on the bump stops as it is now AND get the lifted look I like. Reminding myself it was after lowering the lift to save $$ on tie rod ends and idler arm wear that I started having the half-shaft issues. Let me think…
Control arms are on order.
Today, I’m trying to source replacement front differential from a recycle yard since this one is still dripping despite the ‘stop leak’ remedies. In fact, it’s started leaking on the passenger side now.
