Big T
So you think Engine Restore will correct blowby on the 6.5?
Without looking at a can, I think the diesels not to use it in are the HEUI Ford/Navistar systems that have that close tolerance high pressure oil pump for the injectors.
FSO wire is the fuel solenoid (round cylinder thingy on top of the IP by the fuel inlet) just making sure.I can’t see it hurting the engine and it does help scored cylinder walls some.
Further Testing might be cylinder leak down test, checking for stuck rings, checking for equal kisting of fuel out the cylinders.
just want to verify, you understand remove all 8 glowplugs, remove fso wire, cycle engine a couple seconds, then install tester into cylinders one at a time for readings. YouTube videos help if not familiar.
lol how did you know I was reading that thread on adding a water filter. no worries, not gonna do that. water wetter sounds like a good idea though!DO NOT add coolant filters that have the additives either.
Fill it with apple cider vinegar. Let it soak for a couple of days. Acid in the vinegar cleans most anything and is easily disposed of.Well I guess I will add flushing the system to the list after the compression test! I posted another thread asking about trying to clean and clear up the coolant overflow mounted on the firewall too. I'm wondering if using the power washer on it and a weekend soaking in a tub of citric acid will help!
