Jay-Bee-Kay
I have an '88 Silverado K-1500 and it's been parked for 13 years, because I refused to junk it after my wiring was damaged.
Now I am finally getting around to repairing it after all this time.
It's a California truck which makes things more interesting. So I've decided to convert it to propane, which means it will be smog exempt, so compliance will not be an issue in this case.
The engine is a 5.7 and the trans is a TH 700R4.
I'm not having any trouble with engine wiring. The thing I'm having trouble with is the brake light / TC clutch / cruise control switch.
I bought a Haynes manual because it looked like it had a good schematic and chassis electrical section, but I am finding out that there is very little in the manual that is applicable to my situation.
The thing that I could really use is a good schematic that has info that applies to my wiring. But if I can't get a schematic that matches, then maybe someone could talk me through it..
The wiring suffered it's first blow when a rodent ate through some of the insulation in 2005.
I converted it to a carb and ran it for a short time but the EFI fuel pressure was more than simple hose clamps could tolerate and a leak started which resulted in a fire... Which further complicated an already challenging problem.
Anyhow - I have most of it figured out for the conversion, but the brake light / torque converter clutch wiring is giving me nightmares.
I plan on deleting the cruise control.
If someone could refer me to a schematic or a good electric manual that covers chassis wiring, that would be extremely helpful.
Thanks in advance!
... Hope you are all enjoying these long summer days
PS - I will include some pics as soon as I figure out how to do that
Thanks in advance!
