n8in8or
Thanks
I'm curious FT, why were you wondering that? What plans do you have rolling around in that busy head of yours now!?
Thanks
Increasing feed pressure seems to be a good approach on a mechanical pump say a moose pump. The only time I've seen fuel return lines pop on a 6.2/6.5 is when housing is cracked allowing higher pressure to the return lines but wondering if the lines will stay on at higher fuel return rates if that is even a consideration?I'm curious FT, why were you wondering that? What plans do you have rolling around in that busy head of yours now!?![]()
Man, that really sucks, hope you get it straightened out with them sooner than later. I would be losing my patience with that company about now.I spoke too soon. Looks like the 8 replacement rockers they sent me are 1.5 ratio where as the old ones are 1.6. Notice the difference when side by side on the shaft. The new rocker is the one with rounded corners and the original is the one with square corners. View attachment 44697
Were the old ones damaged? I thought all that was needed was new spacers.
This is looking to be a bad winter to build an engine.![]()
Just got an email from Harland Sharp. They are going to send me the 1.6 rockers today with a return label for the 1.5 rockers. If it all goes to plan I should be ready to rock again tomorrow night (pun not intended).
Glad to see they are taking care of you and fast. I keep checking up on this thread waiting to hear the rattle of that purdy motor in the Ho. I'm sure your chomping at the bit to get this wrapped up.
Nice work on the restrictor.
Got rocker?
