No I have no idea. I'm now getting a constant code 36. Lots of whiteish blue smoke at startup. I can clear the codes but 36 comes back instantly. Pretty much at the point of giving up. Dont have alot of money to spend on fixing it either. It's making a weird clicking and whoosh sound now randomly while idling. All 3 6.5s I've owned have made this same noise except usually they will still out after making the noise. This one hasnt...yet. sounds like it's coming from somewhere in the front.
DTC 29 - Glow Plug Relay Fault
DTC 36 - Injection Pulse Width Error (Time Long)
You purchased a 25 year old vehicle for $750. Have you spent $2,000 on repairs yet? The $2,000 is a ballpark number most used vehicles need in repairs before the owner shitcans it for something else. Maybe you got a good deal that doesn't need $2,000.00 in repairs. And then that would be the other time sucking bastard: electrical problems.
"if I rev it a few times then it turns black."
The black smoke on rev-up is the turbo not caught up. Unless you have snap test emissions:
KNOCK IT OFF! Revving the engine up without a load is a good way to turn things into hot oily scrap metal. Either you have a plugged air filter or you are giving it too much throttle revving up. I digress as you have other problems going from white to black smoke.
As I mentioned:
Does the "Glow Plug" light come on? Yes/No/Intermittent?
If the light is "ON" the "DUMB" relay is getting the "on" signal from the ECM and providing power to the glow plugs (GP). The ECM "sense" and GP lamp are on the GP side of the harness: GP's have power = Lamp on and ECM sees GP relay "on". No volts to ECM from glow plug side of relay = Code 36. Note the ECM doesn't give a damn if every single glow plug is burned out "open". All it tests for is +12 from the GP side of the relay, period. Loose connector not powering the relay would do it. Bad contacts in the relay will do it. Bad wire to ECM will do it, but, white smoke is a clue you may not have working glow plugs.
"Lots of whiteish blue smoke at startup."
Generally the fire is out in a hole or two. Air in the fuel system, bad glow plug system, not enough RPM cranking, pissing worn injectors, injectors allowing air into the lines when off, loss of compression... You can add throttle to bring the RPM up so the other cylinders light off. This is not floor it, but, 1/2 throttle at most. The back of your sun visor has cold weather starting instructions you can use to help. Assume it's cold because: you have some problems.
Page 12 of the 500 PDF linked below says why/when it sets. Other not printed ideas but common failures: air in fuel, PMD failure, PMD extension cable problems, filter harness on optical sensor, grounds, IP failure, lack of lube in fuel.
Looking for the EID assembly elastomer insert drive info and what year it affected of the DB2 pumps to clarify a post of mine for "Ratman" I came across this goldmine. CMY: The Google search I used. :agreed: 1st result: Oldsmobile 1985 doc referencing EID governor here...
www.thetruckstop.us
