92 completely dead
probst55
went to start, glow plug circuit lit up for about 2 seconds then nothing. no crank, no headlights taillights, etc. Both batteries completely charged, replaced 2 years ago. Is there a main fuse somewhere i'm missing. Where to start
Start at battery connections. Load test batteries. If you haven’t replaced the crappy side mount cables for top mount yet, check the little puck that connects battery cables to each other. Check connections at starter and ground cable.
will do, thanks, went through the grounds, what general area would the fusible link be in if thats the problem
On a 92 there should be a wire that goes from the battery to the starter and then up to a power distribution block on the firewall kinda above the starter. I'd be checking that out.
