will do, thanks, went through the grounds, what general area would the fusible link be in if thats the problemStart at battery connections. Load test batteries. If you haven’t replaced the crappy side mount cables for top mount yet, check the little puck that connects battery cables to each other. Check connections at starter and ground cable.
And eventually replacing it with a bigger wire or augmenting itOn a 92 there should be a wire that goes from the battery to the starter and then up to a power distribution block on the firewall kinda above the starter. I'd be checking that out.
I'll be checking that also,thanksOn a 92 there should be a wire that goes from the battery to the starter and then up to a power distribution block on the firewall kinda above the starter. I'd be checking that out.
