2013 lost rail psi
Yay.... more good news....
So should I just plan on lines and injectors now or just see how it goes?
Who do you recommend for a cp3 and injectors these days? Alligator is currently selling kits from industrial injection and HS Motorsports.
Looking at maybe a hair over stock, nothing extreme.
I have metal shavings down to the rails. The shop suspects the injectors ate metal too.
This sounds like my LBZ. When the CP3 let loose, it took out some injectors too. I did it all -- it was over $7k (I did the injectors and hard lines myself and installed the FASS so saved on some labor there). Local shop did the cp3 and egr cooler.
Whatever way you go, hope it treats you well. I've gone about 45k miles since it all happened. I did loose one injector exactly a year after install but no issues since. --knock on wood--
