Update.
Ok. I think I am getting somewhere now.
I actually had 3 individual problems, and This is what I think.
Problem 1. Fuel Delivery problem.
I had a new fuel tank and fsu put in at the garage.
While they had the tank out, I had them change my Rear AUX Lift pump with my old carter I had (works, just changed it as PM with Delco). This LP is In between the front fuel tank (62 inches long), 14 wide, and the frame. Actually, its inside the frame, and the fuel tank is about an inch away, so real PITA to get in there on your back with the tank in the way.
Anyhow, This Aux LP Hasn't run for about a year. Thus, Whatever was in that thank that I wasn't able to pump out in February got stirred up again, as I filled up both tanks to check for leaks.
The guy who changed my fuel tank said I did good by leaving the tank bone dry for him to change. I planned it. Then he said to me, the little bit of fuel that he sucked out got him just far enough to get out of the lift and it died.
WTF, you put that shit back in my tank???????????? I saw the fuel transfer system, and it was what it does, and I hope to god it does some filtering. It had some name like gas buddy or something and that was its purpose. Anyhow....... This pissed me off because I had a 5 gallon thing of fuel and the fuel station on the way closed down and i was in a rush to drop it off for the fuel tank so i didn't go else where.
Problem 2. The day my valves failed I was really pushing the truck up long steep highway grades with my plow on front blocking all sorts of air (9' plow), not to mention making the truck work through the air resistance. As I said, i watch guages carefully, knowing she likes to get warm fast with the plow blocking the airflow. Then Head Failure.
While dealing with the head failure problem, My fuel delivery problem showed its ugly face.
Problem 3.
I have one more injector still in her that the guy who swapped my head felt the need to take apart and tinker with even though I told him not too, before he did a compression test. The other injector was easy to find, it atomized the fuel back into the engine compartment when i cracked it instead of drip, drip, it was Pssst, pssst, perfect cloud of diesel that just vaporized. didn't even get the injector wet.
The other Injector is proving to find itself hard to find. I may just replace the other 4 in suspect, but Napa wants 80 a piece, I'd rather find the bad goose, and replace it for now, as money going all over the place lately.
So, Had to work today, I have all weekend to fix her up.
I need to end this post to save before I begin on a few questions.
