Too short for a new thread in ‘Electrical.’
Years ago, I realized the OEM bulbed 3rd Brake Light / Cargo Lamp fixture needed replacement. Bought an LED unit that worked fine…for a while. Cheap unit that I replaced with a ‘better one.’ All good until a year or so ago, the cargo lamp stopped working. I’d T spliced in bed lights using those guillotine things and then removed and repaired the damaged wires. Figured this was the culprit. Brake light still came on so, ignored it until this week.
After testing components and voltages at points 1 - 4 the issue appeared to be the fixture itself.
1. Fuse 3 was obviously good because all the other shared items worked.
2. Removed and spliced in a new harness connector as part of the wire repair. 12v present on the Orange wire.
3. Tested the switch and all continuity checks were good.
4. 12v present at the connection only when the switch (3) is closed. Confirmed with multi-meter and test lamp probe.
I had bought a replacement 3rd Brake light when the cargo lamp quit but, kept it on the shelf until now. Installed it…did’t work either!?! Cheap Chineesium Parts (redundancy?) or is there another issue? Can’t return the light because it’s probably been too many years and, LMC’s restocking and shipping fees makes a refund moot.
“Reload!” The parts cannon and, with fingers crossed, ordered this one. Works as advertised. “Happy 250I’d America.”
Next project….
View attachment 100256do you have the whites hooked up as backup lights?
