Opinion* dear Lord.Could use an option.
Does it seem like my motor shakes a little too much?
Bad photo. But its the one that attached to the frame sir, it was this mount thoLoose bolts as in the ones holding the mount clam shell to the frame or the single through bolt? if it was the single through bolt. do the same thing again that I mentioned on seeing how much the engine moves when in gear with a blip of the throttle. you can put a little more load on it, see if you feel and see the motor lift and fall back.
I shook both sides, no play or the sound of a pinch moving.how are the pins and bushings on the hinges. that is usually where the issues are.
Shoot if thats a thing someone do tell, ill actually cop that and the shims.I believe on your rig, the hinges can be shimmed, they also make a tool that attaches to the striker and latch to help align the door too. I will let others chime in on that part.
Bottom is slightly pushed out, when i close it closes without anything hitting or soundingIt could also be that the door pillar is tweaked too. when the door is closed, how are the body lines at the front fender? is the bottom also pushed out there as well?
Im trying so hard to visualize adjusting the hinges, does anyone have a video or how to guide of this?The striker pin is that bolt in your pictures that the door latch hooks onto when closed. Barely loosen it, and there is a captured nut behind it and large washers on both sides. It goes through a fairly large hole. By moving it up/down/ in / out you can adjust where the latch area of the door fits when closed.
The hinges are adjustable as mentioned. You can move the top & bottom hinge in and out to get the front of the door to align there. Most folks start at the hinges. Then when the front seem is good the adjust the striker pin.
Basically you adjust the door to fender at the hinges & latch is for the center of thr door. Beyond that- is a bend door shell or bent pillars. The window frame commonly gets bent inward and need simply small amounts of force to bend it back- they get bent by people using it to close the door by pulling on it.
Take it to a maw and pop body shop.Im trying so hard to visualize adjusting the hinges, does anyone have a video or how to guide of this?
