SnowDrift
Ultra Conservative. ULTRA!
Thank you @Glagulator
If a guy could obtain the unicorn, it sounds as though it's capable of doing the job, though, and allows a better fit for the DB2. Is that about right? I still wonder how much that '96 design will flow in comparison to the later dual thermostat design.When they switched sides with the accessories in 96IIRC there was a one year single stat before the dual stats. They're unicorns anymore I had one that I let get away not realizing what I had. It allows the DB2 pump to fit better on later year rigs
This is interesting. Because of all the proponents of the single stat, I left it on the ‘94 which has the upgraded 130gpm water pump and the Dmax fan. However, it still runs warmer than my ‘99. I do have a dual stat crossover on the engine we took out of the ‘95, so I might just put that on the ‘94 based on Husker’s comments.Husker said this:
Look in my signature. Block off thermostat option. Follow the link.Husker said this:
Same components on my ‘94 and ‘99, except for single vs dual thermostat respectively. ‘94 runs at 195 to 200 a can easily hit 210 on a warm day. ‘99 runs at 187 and is mostly pegged there. It and rarely gets over 200 and you must be charging up a steep mountain grade in summer heat.Look in my signature. Block off thermostat option. Follow the link.
Look at the size of those two. If a person is worried about flow restrictions through thermostat(s)- this would have maximum ability.
Also for the dual stats vs single-
It was already actually tested years ago. The single wins.
Someone can do it again if they feel the need.
I’ll try walking through it.
lets say the single stat has 2 square inch of flow area.
And the smaller duals has 1.25 each for 2.5. Now
Account for
100% of the coolant on the single going to the radiator. 2x100=200
75% of the duals IF you have a BRF. 2.5x.75=1.875.
Maybe my 1.25 is wrong?!!? Maybe it’s 1.5x2=3. Then 3x.75=2.25?????
Number theory is cute- but how much actually flows into the radiator and REMOVES HEAT FROM THE ENGINE- that’s what counts.
FOR EVERY PERSON you can find that has ran both the duals and the blockoff single stat- I am willing to bet there is 4 who attest to the single keeping temps more stable for less fan time, cooling off quicker when hot. Warming up faster on cold mornings.
You can find @WarWagon accounts of it here and other forums long before I joined.
Run what you have if it works. If not-then play with it. But as hard as it is to find any rare part- I would say get the ones that Nate found that are in my signature.
I’m going off the shitty dash gauges and the ‘94 gauge is really shitty and suspect. Down the road I’ll be getting a digital gauge cluster for the ‘94.Ive done swaps on the same truck in fleet and on my personal 99 when we were trying to figure it out. To be fair, the 195 stat would move the ect gauge more but keep it steady under or at 195 where as the duals would allow the 210 to happen- exactly opposite of what Big T has in his two suburbans.
When I did the 180 stats and swapped between them- the duals would move between 175-190. The single 180 just lives within 5° of 180.
Keep in mind with mine i was paying attention to how often fan came on and the singles won that regardless of 180/195. This was still running stock fan, radiator, & what we know now as the balanced flow pump. Any old postings from me here or other places I called it the updated serpentine belt pump.
The other thing is my readings were with two quality temp gauges, one mechanical and one digital. The factory pos is a joke. In the fleet they all had an aftermarket mechanical gauge added reading right rear head.
Where he said can hit 210 on warm day- mine of a fleet truck that hits 210 a second time comes into the shop for repairs. You guys seen me say it-
195-200 all day is ok
210 watch the gauge ore than the road.
220 pull over and let idle to normal.
I’m not joking with that 210 - and if you are busy watching a gauge while driving then you are at elevated risk for an accident. That is a get you home/ to shop state. If you know you can hit 210 - fix it, it is broken.
Verify gauge
Clean the radiator inside outside, between stack components.
System flush
Clean & test fan clutch
Thermostat is highly suspicious-
GM went to the dual stats because they ate a bunch of engines when the factory stats were sticking closed. Having one of two stick closed means a controlled overheat. A single stat sticks closed and you over heat and over pressurize quickly. It’s been too many years to remember the brands right now- but GM changed suppliers over it. There was a design of using the dual thermostats that were both block off and the lower chamber came out into one return hose.
Some generators got them. But they had the db2 and oil fill on the valve cover. It was simply too bulky.
Going to the constant bypass was an undesirable compromise. Thats why they had that freshly retired guy redesign the duals and he came up with that restrictor. It wasn’t a simple drilled hole reducing the size- it was shaped inside to affect flow. The whole- put in part and drill it or weld up & drill was a jerry rig trying to imitate most of the effect after he died and GM couldn’t steal his idea.
The sensors for it are crucial as well.I’m going off the shitty dash gauges and the ‘94 gauge is really shitty and suspect. Down the road I’ll be getting a digital gauge cluster for the ‘94.
Well the HO pump and Dmax fan on the ‘94 did not have the same effect they did on the ‘99 and the only difference is the crossover.The sensors for it are crucial as well.
And as AKdd points out- some engines run hotter than others - multiple factors generate more heat before it gets to the job of cooling system to regulate it.
This is why I pointed out having used the different crossovers & stats on the SAME ENGINE.
Crossover is easy enough to swap & test…Well the HO pump and Dmax fan on the ‘94 did not have the same effect they did on the ‘99 and the only difference is the crossover.
I have a gasket installed that is a two layer metal unit. Might be some kind of heat proof material mixed in.Replacing injectors and let’s just say, I’m having to take it a lot slower these days than in the past. Fortunately, I have the time. I guess it’s a good thing I decided to do them because I discovered that two turbo nuts were AWOL and the two outside nuts came off way too easy to my memory of past efforts. Then, I found, for some odd reason, there were two of the gaskets between the turbo and exhaust manifold.
View attachment 98507View attachment 98508
As for the studs, years ago, when I was swapping out ATT, Super 84/86, GM-8 and ‘Hurricane 7’ (GM-8 with modified turbine and compressor wheels) turbo’s for comparisons, I had replaced the studs in this Hurricane 7 and failed to realize how short they were. 35mm in total length but only 20mm after shouldering the stud in the turbo.
I replaced them with similar ones in the picture that have better threads on the turbo side.
There’s been noticeable oil weep on the return hose and other spots. Turbo weep is from three of the compressor housing bolts being loose and the other seems to be the upper intake gaskets being reused too many times, no squish and cracked. i’ve got extra gaskets and I retightened the compressor housing bolts and Turbo Master stud nuts.
Anyway, I have the passenger side injectors in and will do the driver’s side tomorrow. Unless things are an emergency,(proverbial/Biblical “Ox in the Mire”) I don’t wrench on Sundays.
