Turbine Doc
Just Another Diesel Guy
Even Bill Heath ran my FTB when he set the record to beat at Bonneville https://www.motortrend.com/reviews/1006dp-500hp-65l-diesel-race-engine
And frum the website, a copy annda paste wuz nessary.Even Bill Heath ran my FTB when he set the record to beat at Bonneville https://www.motortrend.com/reviews/1006dp-500hp-65l-diesel-race-engine
And this one gives me greater confidence.
"I turbo diesel you long time!"And this one gives me greater confidence.
Partially due to your suggestions @Will L. that's where I am now with a completely torn down brand new Optimizer. It's @Twisted Steel Performance shop now for lots of fun ($$$) stuff. I'm 70 now and the truck is 30, with these improvements it should outlive me and still be going strong for my grandson who helping me rebuild the slushbox now whilst we wait for the motor. BTW transmission is from Monster Transmission (not recommended) with less than 3000 miles on it and was slipping in first and reverse when first installed, lots of clutch material in the pan and he said it looks like converter material in the fluid.I have an optimizer I bought new and the original plan was run it for 100,000 miles, then rip it all apart and make all the changes. I wish I had just made all the changes when it was brand new. That’s why that has become my new standard, I have seen too many brand new 6.5, including P 400, that have failures in under 100,000 miles. I am of the opinion now that all brand new 6.5s MUST BE disassembled and make the changes required.
I woonder if line boring would make bearings all one size, most likely not as thats mostly on journal diameters.Still sitting on it while I finish changes to my pulling tractor. I hope to send the block for machine work (make sure everything is square and in line) next month, and I need to get the pistons first.
Curious if a block has to be line bored if they make main bearings that are oversize on the OD rather than the ID when a crank is turned.I woonder if line boring would make bearings all one size, most likely not as thats mostly on journal diameters.
I might have a usable 1999 block, though not a Navistar. I lost the engine at idle speed when I lost a braided stainless oil cooler line. Engine seized but never overheated. I have it in a crate in the garage at our Montana home, but have yet to tear it down for inspection. I know that shipping is profusely expensive. If the heads are good, I promised them to MrMarty.I've been going over things lately looking more and more into a summer project of attempting a cylinder hone and re-ring job on my 93 to try and save the engine. the more and more I look into it I am seeing the cost factor for what it would accomplish and thinking it's not worth it. if the parts weren't so high in cost I would do it. looks like I would be spending almost 1k in parts to trim the ring ridge, hone the cylinders and replace all the rings, along with all the gaskets timing chain and oil pump. Just to slow down blow-by and be able to trust it for longer trips.
Remembered this thread and thought I would look into usable blocks.
