Timekeeper explosion in P400
CursedH1
Active Member
Figured I'd go ahead and post here as a warning to others.
Timekeeper set installed in a brand new P400 in 2022. 20k miles on the motor and Timekeeper set. Around Thanksgiving I noticed a knock coming from the engine, then found glitter in the oil.
Thankfully the pieces of the exploded dogbone were found and the engine is being rebuilt. This time with the standard timing chain.
Wow, that is wild! How bad did it mess up the engine?
Thankfully the engine itself appears to be as unscathed as possible. The pieces of the broken dogbone are accounted for in the oil pan but there still was glitter. On Monday we order all new bearings/gaskets/seals/gapless rings. Already have all new ARP hardware ready to go. Also taking the opportunity to change to the P400 DS4 IP.
Has the cause been determined?
Not sure we'll ever really know - but I know that there was a thicker gasket put on the water pump / backing plate to make sure that the "dowels" didn't interface with something they shouldn't have when they were installed.
@CursedH1
There is no gasket from the factory, I don't use gaskets, the idler gears are supposed to be put in place and the clearance of the shafts checked so they will float.... I use clay for measuring the clearance, I go for .050" clearance... This is after the fact your gears bound up and things went to crap, those marks could very well be from the gear being pushed around... no true way of pointing fingers as to root cause now.
The gm and first navistars had gaskets, butas Chris mentioned the p400 didn’t. I am wondering if there is s depth difference in the timing cover mounting face to the block on p400 vs gm.
I’m convinced the axles were pinched.
The axles have to float freely, if they get pinched the axle binds ever so slightly and will sideload them into the gear. Thats what causes the axle to spin with the gear. See the rotational marks on the timing covers?
The one side could be argued it spun after the dogbone failed & thats the cause of the spin on that side. But obviously both spun.
My gears are spinning in my head. In racing these were the common upgrade the whole time I was in that scene. Seen a few fail but never like this. Hmm…
When the water pump was replaced back in September - my mechanic said he had to use a "thicker" gasket in order for the dowels/shafts to not interface with the timing cover. So he did notice them touching the cover but perhaps it wasn't enough.
Obviously it wasn't, the directions say to grind the shafts for clearance.... those gaskets that can be purchased aren't anywhere close enough to get .050" clearance unless a person uses 8-10 of them....
I thought I remembered removing the cover when I changed the water pump in the 1996 over a decade ago.
It seems like there was 2 through bolts or it was leaking or something
Original engine in my truck, when I purchased it, leaking coolant between the timing cover and the head, right against the head on the RH side.
That required removal of the timing chest/cover.
Same subject is on Hummer forum. This is my copy/paste from there:
So far im at 4 pms, 3 texts, 1 phone call about “I am” or “should I” go back to chain…
This is the first set of failed gear drive I have seen in any 6.2/6.5 . I have no vested interest in these being in existence or not. My personal experience is they are worth a long term investment in time & money. If there is any pictures of others that failed- I and plenty of others would like to see them. What I see is that either the mechanic didn’t have proper install instructions or didn’t follow them. While that is opinion, i have seen this type failure before on sbc and bbc engines. The popular thing on those was a chrome timing cover thats very thin metal and they usually start leaking oil as they damage the cover much easier. So seeing gear drive failure is not new to me.
It is definitely more work to properly install the time keeper set. Adding them is a decision to do a lot more work on day one with the intention of never touching the cover or gears again. The alternative is periodically replacing the timing chain & gears set like is done for timing belts in newer cars.
If I misled anyone that these are slap in & go, I apologize. They definitely are not to be treated that way. I know talking to friends of mine that we grew up together we actually say “slap a set of rings & bearings in…” but never is it just that. There’s a ton of little things that always goes along with it. Like telling my kids when they were young to “get dressed by 7am” I fully expect them to shower, brush teeth, etc. and never think twice to explain fine details.
How often a person needs to replace the chain changes on their use. If a guy has a stock engine, has a hmco, never tows, and a ds4 ip- drive it and ignore the timing chain for 150,000 -200,000 miles.
Different things all increase the schedule for replacing it. The more there are the sooner or the higher the risk of issues.
Heavy loaded; heavy towing; higher speed driving which requires higher rpm; offroading where high rpm is used; where “feathering aka jabbing” the throttle is used frequently; pushing the engine for more power; reworking/ replacing rocker arms for higher ratios; replacing camshaft for more lift or extended duration on the intake valve; changing cam timing;
I’m sure there is a few more but this should get the idea there.
People with db2 should readjust their injection timing every 30,000 miles. That’s about a normal rate for a chain to stretch. When the ds4 was designed, the timing issue was a known problem, remember GM once had an option you could pay for 100,000 miles warranty. So they had stanandyne build in a timing corrective feature that helps with this. It doesn’t solve it but masks it enough that 99% of owners can’t tell the difference. But by the time you put 90-100k on, anyone driving a low mile engine then drive the other will notice somethings off.
In the fleet of 6.5 trucks, many of the trucks were used like a car- simply transported a driver and a couple hundred pounds of material or money is all- and those trucks simply had to have the scanner plugged in and do a retiming while we did other maintenance. Because of the scheduling where we replaced belts, hoses, etc at 100,000 mile intervals- we retimed all the trucks where we weren’t doing testing regarding the timing. No difference was felt by these drivers.
But drivers who worked the trucks- service body one ton full of tools & parts, guy that towed stuff around, office personnel who had company trucks and towed boats & campers often- They would notice the difference right away.
We saw the difference in tracking the fuel consumption. All vehicles had miles reported every fill up.
On trucks that we left the stock chain in for its life in the testing- power and mpg were very noticeable drops by 250,000. For the studies, we were doing emissions testing before it was a requirement to smog diesels here. By 150,000 it made a noteworthy impact. By 250,000 it was enough to make what now fails a truck to pass. I cant remember for sure but think it was close to 15% in fuel efficiency drops.
The question came up on TTS, why did the mechanic mess with timing cover when swapping waterpump. Idk that but I will tell you it becomes standard practice for this engine, & I will always recommend: when someone changes a waterpump on a 6.2/6.5 to replace the timing chain at the same time. The labor isn’t a ton more, the part is low cost. So waterpump, chain, front main seal, and if anything looked less than perfect the cps also -was all done at once in my shop.
There are guys running a lot of power in these engines. I ran them and had timing chains. By time you are 275hp, you loose the option when to change the chain. It is an abused part. 75,000 miles and injection retime interval is 15,000 miles db2, 30,000 ds4.
Anyone doing anything with valve timing- 1.6 or greater rockers, cam timing, camshaft, etc. I learned to just replace the chain every 50,000 miles.
On my race engines that were high rpm- the #1 cause of failure was valve to piston impact. Those chains could not handle 5 miles of dragstrip. I was buying just chains before GM sponsored me. 4-5 passes and the chain was stretched to the point of noteworthy power loss.
That is why I took some Pete Jackson gear drives and tried finding a solution. By redoing a set of Pete dog bone, and a couple custom machined cam& crank gear, I did my own set.
Gear drives steals a few hp on a new engine. By the time you have 75,000 miles on the chain you lost more than the gears will have and thats if you retime your injection. I know the dyno numbers show that. What I never tested was how much power loss is offset by coating the gears with the friction modifier coating my guess from seeing the numbers on industrial equipment is the power loss should be negated, and unfortunately no- coating timbing gears for a chain doesn’t help- it’s been tried.
I have sent chains to chryo treatment. It barely made any difference, if at all.
People send their gear drives in for chryo and about 90% claim worth it.
But these are lightend gears- definitely not the heavy cam gear of Leroys/Dsg.
If this engine was a 7,000 rpm engine the cam gear weight would be an issue. But 5,000 rpm engines do fine with this weight.
The loss of chain slap is a far greater improvement than rotating mass from changes when feathering/ jabbing the throttle.
If a person isn’t sure- then go into detail with your build and everyone can chip in opinion of good and bad for a particular build.
To just change a water pump the timing cover doesn't need to be touched, the water pump backing plate bolts to the timing cover...
I don't know all of the details. I don't know why the timing cover was removed during the water pump replacement. I don't do that level of wrenching on my truck.
The mechanic is one who I have used and trusted since I got my first H1 back in 2018. He did the original P400 swap - with the same gears back in 2022. He's been as good to me as family. I sponsor his daughter's race team. Thats what hurts the most about all this. The fact that I still haven't had the balls to call him and tell him what happened and what I suspect the cause was. Despite what happened - the engine is a machine, it can be fixed. Good friendships not so much.
The engine is being rebuild at a different mechanic down in New Hampshire. One who owns his very own H1, is known in our little community, and between him and his old man (its a father/son garage) have rebuilt "dozens" of 6.2/6.5s.
The owner's manual maintenance section from like 1993 2500 Pickup (or was it our 1988 6.2 ... I am fuzzy on it) says to adjust the timing on the DB2 every 6 months. That's 7500 miles average of 15K miles a year. The chains go on tight new and are sloppy at 30K miles.
Never had a timing change break and they aren’t hard to change.
Do you mean Vs. the modern s#itbox vehicle with zero room to work on anything? 🤪 Not hard you just tear EVERYTHING off the front of the engine because it all has an attachment to the waterpump. The bar is set low enough by GM as it is with nearly 1" of chain slop allowed. No need to drop the bar to the ground with "Like a Snap!" criteria.
The exhaust valve stems fatigue flaking from sloppy chains (but within the huge GM Slop Spec) I thought I had documented well for several engines.
If one be uncomfortable one could verify they installed the gear set properly and check it going through either the water pump or bottom end. (Eh, I pulled the oil pan off my failed 6.2 and was able to check this clearance.) Here is a reminder of the unsuitable for a purpose of driving the shock loads of the IP stretched chain in your 6.2/6.5 GM Diesel:
@CursedH1 Not only do I nominate you for the @WarWagon Carnage winner of 2025 I respect you posting up as this is some detail I feel I could overlook. IMO you have your answer and can confirm lack of clearance even with the broken parts. I went back to my install thread to confirm I had indeed checked idler shaft clearance during install of the timekeeper. Sure @Twisted Steel Performance has a better way to measure it posted up. Now that you have your answer as to why it failed you should feel comfortable putting another gear set in. Sad to see one return to one component of the "disposable GM diesel engine design" the aftermarket has solved.
I am sure the oil pump ate the glitter, however I am curious as to how much the oil filter caught and what may have gotten past the oil filter causing other bearing damage. I do look forward to what you find.
