ak diesel driver
6.5 driver
As rough as that is idling I'd suspect that there's still some air in there.
It smoothed out immensely after a few minutes.As rough as that is idling I'd suspect that there's still some air in there.
For the db2 a simple gasser timing light and one of these is all thats needed
Incase the link dies look in picture.![]()
Gunson 77089 Diesel Adaptor For Timing Lights * pulses * 5053155133630| eBay
Gunson G4133 Timing Light Advanced Dial Inductive Xenon ?. White Light?. Gunson G4062 EeziBleed Brake Clutch BLEEDING TOOL Kit + MULTIPURPOSE CAP 15-67mm. " Genuine" Gunson G4062 Eezi Bleed Brake Clutch Bleeding Tool Kit.www.ebay.com
There are many manufacturers of these i just grabbed a random one of ebay.
The picture is of my Mac Tools branded one. ET18DPM is the part number. You clamp the sparkplug pickup clamp on the red loop of the tool. Clean the outside of the injector line and clamp on the ground clamp and pickup clamp.shoot light at timing gauge just like a gas engine. A local guy bought a $50 Taiwan unit 5-6 years ago and still uses it working in a diesel shop. Still works fine, that one sells for $75 last i saw. Really not the best for ds4 obviously but it will tell you your timing by the injection event to as accurate as you can see the balancer mark. So within 1 degree is not bad...View attachment 61496
Well it RIDES smoother, its always shaky on start upThat is smoother? That thing is shaking a LOT. That is a rough idle.
Does it idle smoother after being warmed up?
Positive no air through ip?
Yes get the timing adjusted. The timing adapters are getting more expensive. But read this post if you want to get the tools yourself. You need this adapter piece and an old school timing light. On amazon they are $230 now.
The last time I checked, the lines were, someone did mention that me installing shorter injectors could have affected the timing by a hair and to get it checked out (which i will, given that i don't know when the last time this thing was checked at)Suspect the IP is wore out and or timing is off...
Are the timing lines lined up on the pump and cover?
Thats the onePump timing tool (?)
Pump Timing Wrench
Put the pry bar down and use our custom made injection pump wrench to make adjusting your DB or DS injection pump a breeze! Simply slide the tool into the existing slots and use a 3/8" breaker bar or ratchet to get the leverage required to rotate the pump. The positive engagement gives you...quadstartuning.com
Is there now wires hooked to that solenoid ?Currently don't have access to my 6.2, im assuming this is the cold advance solenoid?
View attachment 95770View attachment 95771
Looks eerily familiar to the missing connection I found in the back of the firewall when putting on the new injectors:
Disregard this video, so yes my high idle does work, though i took out the fuel sending unit solenoid, not the cold advance solenoid, ill redo this test when I canDid a test, this happened, is pulled the wire and my motor shut off
