It currently runs and idles well,probably a tad smoother than prior to me swapping out injectors, though nothing crazy different.
It still smokes alot during a cold start, which Im starting to atribute to the timing being out of wack, cold advance solenoid not working properly, or, the glow plugs not firing up as they should.
It gets down to -20°F where im at, I need to winterize this vehicle, as my impala has begun to sound horrible (https://photos.app.goo.gl/JrGpXXKBR7WveuLX7)
What do you all think? Ill get the timing done at a Diesel shop, but thoughts on the other factors that I have listed?
That is smoother? That thing is shaking a LOT. That is a rough idle.
Does it idle smoother after being warmed up?
Positive no air through ip?
Yes get the timing adjusted. The timing adapters are getting more expensive. But read this post if you want to get the tools yourself. You need this adapter piece and an old school timing light. On amazon they are $230 now.
For the db2 a simple gasser timing light and one of these is all thats needed
Incase the link dies look in picture.
There are many manufacturers of these i just grabbed a random one of ebay.
The picture is of my Mac Tools branded one. ET18DPM is the part number. You clamp the sparkplug pickup clamp on the red loop of the tool. Clean the outside of the injector line and clamp on the ground clamp and pickup clamp.shoot light at timing gauge just like a gas engine. A local guy bought a $50 Taiwan unit 5-6 years ago and still uses it working in a diesel shop. Still works fine, that one sells for $75 last i saw. Really not the best for ds4 obviously but it will tell you your timing by the injection event to as accurate as you can see the balancer mark. So within 1 degree is not bad...View attachment 61496
Well it RIDES smoother, its always shaky on start up
Suspect the IP is wore out and or timing is off...
Are the timing lines lined up on the pump and cover?
The last time I checked, the lines were, someone did mention that me installing shorter injectors could have affected the timing by a hair and to get it checked out (which i will, given that i don't know when the last time this thing was checked at)
I was also told about the cold advance solenoid possibly not working aswell, which I could see as a possibility
I came across the video aswell, the more i watch it, the more i actually suspect that's also a factor
Tell me not my motor sounds similar to it
But what do you, and the others say?
With that 6.2 in the video, has dual exhaust, each pipe is going to sound different than Your single exhaust ever will.
Your exhaust sounds a lot better than what that one does.
That other 6.2 definitely has something going on with the misfiring of the cylinders.
You need tools to keep Your Blazer in good running condition, buy that injector line/tube timing tool then You dont have to rely on a shop to check and adjust Your timing.
Remove and check that cold advance stepper motor. If its like the advance stepper motor thats on My DS4 pump then its just two screws, unhook the motor and see if the shaft is seized. The advance stepper motor on my pump was seized solid, it had kicked a code, mine is OBD2.
And, like @ak diesel driver showed, a lever reversable 15mm gear wrench, cut and modified for loosening/tightening the injection pump nuts. IDk if the fasteners holding the pump to Your engine are American Standard or metric but choose the right size wrench then saw the head off and build Your own wrench. That will require a welder, if You dont have means to saw off the gear wrench and weld on a proper handle, a friend that does is a mighty handy tool too.
Also, QuadStar tuning sells a mighty handy tool that hooks to the injection pump, a 3/8ths drive ratchet or flex head plugs into that tool and it makes turning/adjusting the timing on the IP so much easier.
Then You will be set to check and fully adjust the timing on Your engine whenever You may want.
Pump timing tool (?)
Thats the one
Currently don't have access to my 6.2, im assuming this is the cold advance solenoid?
View attachment 95770View attachment 95771
Looks eerily familiar to the missing connection I found in the back of the firewall when putting on the new injectors:
Is there now wires hooked to that solenoid ?
Are those wires long enough to reach.
Makes me wonder why there are two wires connected to one function
Your “oh-ohh” red wire is power to the fuel shut off solenoid. Key on send power to that solenoid and allows fuel to flow through the ip and keep it running. You unplug and engine should die. How to force run 6.2/6.5 is 12v to it & spin engine.
If you cant shut off engine because it fails, pinch & hold the 1/4” fuel return line (the one we say replace with clear tubing) when fuel flow stops the ip will stop flowing fuel and the engine dies.
I’m still waiting to see the video of the clear line from when you start the engine cold. THIS IS A CRITICAL PART OF THE DIAGNOSTICS.
The two green wires get power when the ect is below 160f, there is a sensor in the passenger rear head that the green wire comes from.
