92 completely dead
probst55
went to start, glow plug circuit lit up for about 2 seconds then nothing. no crank, no headlights taillights, etc. Both batteries completely charged, replaced 2 years ago. Is there a main fuse somewhere i'm missing. Where to start
Start at battery connections. Load test batteries. If you haven’t replaced the crappy side mount cables for top mount yet, check the little puck that connects battery cables to each other. Check connections at starter and ground cable.
will do, thanks, went through the grounds, what general area would the fusible link be in if thats the problem
On my 94 I went directly from the battery to that distribution block with a 4 gauge wire. Battery voltage gauge is much more accurate now too. No fusible link either
I did similar, but I have a breaker right off the battery.
I augmented the original wire. With the heavier wire.
I used this breaker
You can always install a 100 amp breaker similar to the ones used on car stereo amps. something that is re-settable and will mount on the firewall next to the distro block.
I second the notion to run a heavier gauge wire direct from the battery also. GM is known for using wires that are barley adequate. GM bean counters saving their cost anywhere they can!
as far as it being protected. yes and no... every circuit in the cab is protected by a fuse, but some of the leads coming off that block go direct to other things like the alternator and whatnot. on most rigs of this age, it's always recommended to replace the battery cables with heavy cables to the starter and for the grounds too. including the wire off the back of the alternator. most from factory used between a 2 and 4 awg cables off the battery, going with 1/0 cable is the way to go with the 4 awg for the distro block and alternator. running a diesel with dual batteries, ultimately you need to switch to use top post and get away from the side post batteries. when I replaced cables, I had regular copper lugs soldered on both ends, you can run the side post batts until they die, then when going to top post, just get the bronze / copper marine terminals to connect. stay away from the lead terminals, they corrode and fail in a short time.
This is what I used.
I've never had issues with the side posts after using the Allen screw for the battrry bolt upgrade
I always buy dual post. Group 34/78 DT
the main issue with side posts is corrosion that gets in there and you can't see it especially with the factory GM cables that have the boot over them. also with the little spacer that allows double cables. dis-similar metals cause a chemical reaction, that happens with happens as well with residential and commercial wiring too! always use dielectric grease to seal from the environment!
Dielectric grease is good but, I prefer Noalox. Noalox works similarly in that it provides a good weather seal but, it is a contact / connectivity promoter and an Anti-Oxidant; improving the connection between the metal surfaces vs dielectric which prohibits connectivity (which is why you can put it across the positive and negative terminals on bulbs…bulb grease). That said, don’t use Noalox on your bulbs or in two or more weather packed connections. Bad things may happen.
Been using it on battery and ground connections for years. Drive on the salt flats, winter etc. and have never had any corrosion on the connections.
How about this stuff ? ? ? ?
It is like a fine/thin grease. Made for Truk-Lite, makers of many wehicle lighting products.
I was introduced into the use of this stuff when still working for the Montana DOT.
