Big T
Installed a turbo oil drain kit from Quadstar on the ‘94 K2500 Suburban. Mostly went well, save for the final step of installed the tube into the block plate. There are two o-rings and the first one kept sliding up out of its groove when it should go into the block plate. I think I should have first installed the tube in the block plate, then install the block plate onto the engine.
Spent hours on this and finally gave up. I’ll have some rework to do down the road after this brief trip to Montana. The intention is to finish this with a Pro Vent catch can that continuously drains into the engine. It also cleans up a chronic oil leak on this truck.
