It’s like a mechanic- some great, some not, some complete hacks.Her surgeon showed her the complete map of the areas he ablated. It was some 40 to 50 spots. She felt like it would be a recurring scenario, so she opted for the permanence of a pacemaker. I have little say in this, but the decision is surprising. Given what I’ve gone through with my foot, I am not a believer in modern medicine.
Well I got the Burb home. Had to use a commercial service and will seek reimbursement from AAA who could never get their act together. After I got home, I put back the outer main entrance door that I had been working on and then just crawled into bed and went to sleep.It’s like a mechanic- some great, some not, some complete hacks.
Then like a truck, some have enough internal problems that great mechanics have a hard time, some just go forever even being mistreated.
Thats where my truck is leaking from too.They were upgraded to braided stainless, but could be possible. It was really leaking down from the center front of the engine, whereas the oil cooler lines are off to the driver’s side.
Tomorrow will be a long day for both of us with April’s procedure appointment at 9:00 am. Bunch of cardio electrical work before they start the actual surgical procedure.
And great resultsWe wish April a fast recovery from her procedure.
Wishing all the best on her procedure. keep us posted how it all goes, I'm sure she will bounce back stronger and ready for adventures!Well I got the Burb home. Had to use a commercial service and will seek reimbursement from AAA who could never get their act together. After I got home, I put back the outer main entrance door that I had been working on and then just crawled into bed and went to sleep.
She came through it fine. She’s awake coming out of anesthesia and reading in the picture. I got her at home. She ate dinner, then went to bed.Wishing all the best on her procedure. keep us posted how it all goes, I'm sure she will bounce back stronger and ready for adventures!
If this is the same one you pulled the old marine injectors and installed new, it wasn't that long ago. iirc this might be where you replaced themWorking on the ‘99 pulling the injectors to get them tested. Paveltolz is stopping by in the am eventually on his way to Bill Heath and he will take the injectors to have them tested. I could go back and search posts to see when I put them in, but it was in the last 2 or 3 years and about 12K miles. Same with the water pump. Just trying ID which parts can go over onto the new one. Like I just replaced the engine mounts two years ago with Energy Suspension black urethane, so those are still good.
While under the truck removing the down pipe, based on the plume of oil it does look like an oil cooler line failed. The pumpkin on the front differential is coated 360 in oil. I haven’t inspected over there.
Did you try a screwdriver or jumper wire?Got a call from Paveltolz who was traveling with his wife from Helena to our home in Stevensville. Had filled up the 1500 w/ 6.5, pulled away from the pump and parked in front of the convenience store, but would not restart. Starter doing nothing. Paveltolz said he had all the requisite tools, but could use a floor jack and stand. Threw those in the ever reliable 2023 4Runner Off Road Premium and head towards Drummond, MT. Stopped at Napa in Missoula and picked up a new starter. Met Paveltolz in Drummond and go the new starter installed. Same result: nothing. All fuses testing good. 12.5v at each battery. Jumper cables no change. AAA is their usual shit show trying to find someone to do the tow to my mechanic on our loop road. We have a commercial tow who will do it, but probably tomorrow. Paveltolz is doing trouble shooting while on the phone with Bill Heath. His Apple Car Play head unit is bitchen. I want.
