Will L.
We are talking less than 1 cup of flour here
Not too many kitchens blowing up over bread or cookies.
Unless you turn the gas on in the oven first, then light the match!We are talking less than 1 cup of flour here
The Chicago news station had a post about throwing flour on a fire to smother it.Unless you turn the gas on in the oven first, then light the match!
Why grain elevators and flour mills explode.Throwing enough flour would smother a fire but only long enough to get it under control to douse it with water. mainly because it's not "in the air" and a large lump going boosh on the flames all at once. if it goes into a cloud of flower dust... well that's another ball game LOL
picked up a 97 burb for parts today, supposedly has a new transmission. The engine  is supposed to run and the part it needs is supposed to be inside. It also had these wheels and tires on it. 275/55/20 with pretty  good  tread,  one tire has some waves on the sidewall but the others look  good. Can get another on Amazon  for about $203.
Tomorrow  I'm going to get some  abs glue  and see if it is compatible with the fan shroud  material.The plastics epoxy I bought worked pretty good. It might have been jb weld. I think I got it at MenardsGet some that works on multiple types of plastic. Iirc, the fan shroud is imjection molded, fiber-reinforced polyethylene. It certainly isn't ABS.
