jrsavoie
Recruit
Where do the problems arise using the Right Stuff?
Has the product changed?
Stuff I had was black and thicker than the new cheeze whiz container. New container was grey and not as thick as the old black stuff.Where do the problems arise using the Right Stuff?
Yes, RC for valve, or rocker cover.RC = Rocker Cover? aka valve cover?
I used the Dorman units. Stamped steel is stamped steel.
I really think you should consider the cork gasket under the cover and the girdle directly on the valve cover.
Mine is now barely leaving a spot if any at all. I do have leakage on the frame under the turbo drain. The drain pipe was installed to the turbo with no gasket and probably need to fab one for that.
Corked mine. Sourced the studs and flared nuts through McMaster-Carr, Ace Hardware, Tractor Supply or your favorite nut and bolt store. M6 x 25mm 1pitch studs, black oxide. Steel Nonmarring locknuts (aka Flared), zinc coated.Thinking about those neoprene gaskets that Leroy sells. He has a very limited quantity of those.
I usually use stainless serrated flange nuts. For no more than I use. Total expense doesn't add up too fast.Those are called flange nuts for anyone trying to find them. You can get them with a smooth bottom or a serrated bottom and you can also get them with a pinched top for locking.
The “NonMarring” blah blah was off the McMaster page. Weird.Those are called flange nuts for anyone trying to find them. You can get them with a smooth bottom or a serrated bottom and you can also get them with a pinched top for locking.
Cork gasket under the cover, girdle directly on the cover.Got some of these load spreaders. These is for a SBC engine so the holes is too small for the 8mm studs for our 6.2/6.5 heads. Drilled them out one bit size over a 5/16ths. 21/64ths or some such.
There is a longer version and if the ones for the 455 Pontiac can be ordered then the holes is for a 3/8ths size bolt and dont need to be drilled. The ones for the SBC engines looks mighty narrow around the outer portion of the bolt hole loop so I dont thing there is enough meat out there for drilling to that 21/64ths or whatever size it is, making them too weak to hold pressure.
I did a search for Pontiac 455 V8 and there is all sorts of these come up, mostly with bolt holes to fit the SBC engines with the 1/4” bolts.
Need to call Summit or some other supplier to make sure the ones I order is for the BB Pontiac.
SBC units ranges from about $12.00 to into the $30.00 range.
If the Pontiac units is about $30.00 then I guess I’ll forget about a two sets of those.
This ^^^ I did wonder if it might be better to apply the sealant to the head side. Thanks for that confirmation.I know some have trouble with leaks, knock on wood I have yet to have a leaker in the many I've built. I found the flange on the cover is wider than the rail on the head, thus if sealant is applied to the cover it almost misses and does miss the head rail in the corners.
App " the right stuff " on the head rail first, a nice tall wide bead, let sit for a good while, while waiting, apply a bead to the cover, not as big as the head tho, let that sit a while.
Then install cover and only lightly wiggle it, don't push down much.
Take a q-tip or something and clean out and line up the holes, install the bolts loosely only, gently push the cover down, the idea is to NOT squeeze the goop out, next day snug the bolts.
Don't rush it and you won't have a leaker...
The back side of the left cylinder head is near impossible to get sealer onto.This ^^^ I did wonder if it might be better to apply the sealant to the head side. Thanks for that confirmation.
Yup, oil leak HAS to wait. Old 88 Buick plugging the working stall, CV axle be here tomorrow, I hope.Looks like the oil leak can wait... time to grab some fishing gear and have some real fun!!
It’s almost like someone wiser would have said something like rest one day a week.Sometimes a day of relaxation free from all reality makes it when you return to the chores of duty. everything starts falling right into place!
Seems I may have read that somewheres, maybe in a book or some such.It’s almost like someone wiser would have said something like rest one day a week.
