I hope I did okay. I ordered this set from Amazon.
Amongst some stuff that was give to me is a 110 volt Dirt Devil vacuum cleaner. It has a suction hose that can be connected to the vacuum end. With the bag removed there is a tube that air blows out through. I believe that this little vacuum cleaner will make Me a smoke machine. I have some rough ideas how it will go together and I’ll be advertising to the various fakebook groups to try and find some smoke bombs. Fourth of July kinds I think will work great. Rig up a coffee can inside a five gallon bucket with a little sand in the bottom. Use a pour spout bucket lid and attach the suction hose to that, another small vacuum cleaner hose out the back and attached to the CDR port on the rocker cover.
See if that will work. If the smoke bombs is color smoke that might be to an advantage. Maybe the smoke would be more visible under the ultra violet light.
Any how.
Headed to the cabin last Friday. About 18 miles out a big cloud of smoke from under the truck. I pulled over immediately. Looked it all over. See drips from under the truck but cant tell where it is coming from. Called triple A. They no longer respond. I was pulling a utility trailer. My son behind pulling the lake boat. He goes back to town and drops the lake boat. Comes back out and hitches to the utility trailer, I spin around on the interstate and head back to town, hoping the leak aint so bad that it catches afire.
Back to town I drop the bottom covers and fire it up. Just cant see good enough to tell where the leaks is at.
The son gets there and I borrow the step sons 6.2 gasser GMC and rehitch to the trailer and we then go to the cabin.
Now I’m thinking I should just pull the engine and do a total reseal job with the new rocker arm covers. But that would be more than I need for right now. Maybe a project for this winter. Right now new R A covers, new oil filter adapter gaskets and new oil cooler hoses. Whats on there now is high pressure, high temp hydraulic hoses made up by the PO.
Maybe with the home made smoke detector I can check the engine for leaks before firing it up.
