Just knocking out punchlist items and stomping out emerging stuff.
- Driver’s seat rocks, roller missing. Sourced replacement at Pull It yard. FAIL. This one isn’t for a reclining seat. Didn’t notice till after de-rusting, treating and painting. Found a perfect condition, color matching hood there though. Will go back on Monday.
- Remove excess add on electrical wiring crap:
The rebuilt Leroy High Intensity Discharge tail lamp housing melting reverse lamps
Remote Starter Switch
Air Dog Harness
- Restored Trailer Harness with new 4-Pin connector, extended the reverse light lead for future upgrade to a 7-Pin set up.
- Removed the old busted Tailgate light bar, and install replacement RECON Light Bar saved for the eventuality.
Ran two power leads from front to rear. One for RECON power to Under Hood Relay Box w/ Add a Circuit. The other, rear facing LED Work Lights maybe? Keep the other two factory lines for trailer brakes and whatnot.
- Emergent Issue, Replace Headlight switch (Spare on hand). Been teaching my 7yr old grandson about Schematics. I dubbed them ‘Google Maps on paper’ for all the electrical stuff. He’s fascinated as I’ll explain something like the wire runs, show him continuity, circuit tester lamps and then wire in something. Check it out afterwards and it works. That’s how I discovered the tail lights themselves were out. Switch was wonky and it’s too long to post up w/o a separate thread. Suffice it to say, we did the tests and discerned it was the switch and I had a spare ‘for just such an emergency’ on the shelf that I was miraculously able to locate without turning the garage upside down.
- While searching for the Headlight Switch I found a couple of Under Hood Reel Lamps. Took one apart, cleaned it up, corrected contacts that had stopped contacting, did a continuity check, reassembled and installed.
- Another time killer this morning; I noticed the right headlight was out. Figures. Been ridiculing all the Utah ‘one-eyed-Jacks’ lately and, as it turns out, I R 1 2.
Grandson 3 dropped in and when it was time to go home he wasn’t having it. He even braced against me, the roof and the seat. Normally that behavior of someone getting tossed in the back of a patrol car who doesn’t think the law of the land applies to them (Karens).
