Last weekend I wrapped up this truck for now - it’s good enough to start driving again.
No pics, but I installed the updated front diff actuator and harness so the 4wd engages faster.
A couple months ago I got a used tire to replace the mismatched one that came on it, so I put the 265/75/16s back on it. They fill the wheelwells much better and looks more like it should.
I worked on the wastegate vacuum system and even with no vacuum leaks and a new solenoid it still wouldn’t work, so I finally scrapped it and decided to go with a turbomaster. I only had one for the later GM8 style turbo in stock here, and since this will eventually be getting a turbo upgrade I didn’t want to spend money on another turbomaster, so instead I made an arm for the turbo to work with the earlier turbomaster. It maxes out at 7psi, so I think that’s fine.
To address the fuel gauge issue, I robbed a fuel gauge motor out of another cluster I had laying around.
I have driven it a couple times since getting this stuff wrapped up and I have noticed a couple things…. It still stumbles once when I first get on the road and then again first time I floor it, even if it’s 5 minutes into the drive, so I’m not sure if I’m getting some air intrusion, if there’s still some air in the system being worked out, or if the IP is hurt. I’ll keep monitoring it, but it seems good enough to drive now. I have also noticed that while the fuel gauge is working now, it does have an 1/8 tank twitch, though when I was on the way home from filling up the tank, I noticed it stopped twitching about halfway home, so maybe it’s working itself out? We’ll see.
I’m glad to have it back on the road and be able to work on other projects.
