The best, Banshee controller ... The fleese doesn't compare from what I've read.
They are for coolant flow between the valves and when plumbed in will lead to the water crossover. If yoy look at my past pics of a head cut apart, that passage is a dead hole and air is trapped water will sit, this will allow flow and all the air to be purged from the system...What are all the 45* and 90* fittings on the heads in the valley side of the engine for Chris?
Thats a nice addition! I wonder how much better cooling performance just that modification will bring.They are for coolant flow between the valves and when plumbed in will lead to the water crossover. If yoy look at my past pics of a head cut apart, that passage is a dead hole and air is trapped water will sit, this will allow flow and all the air to be purged from the system...
Considerable, would be my first guessThats a nice addition! I wonder how much better cooling performance just that modification will bring.
Chris, I see the two head sections where one is not threaded and the other is, the one that's threaded seems to have that cavity blocked off where the other isn't. also I assume that tee part of the port comes from a water passage in the block?
