MrMarty51
Oh yeah. I suppose the light is fed + voltage and to turn it on continues the grounding circuit.
Ask! Both our local AAP and O'Reilly's stores (several of each in town, as well as AZIf only AAP would price match that lol
Oh my God, Big T is going to explode.Hey fellas. today for what ever reason I had something eating at me that made me want to connect the scanner and check for codes.
Don't ask me why, idk.... the truck has been running fine with no hiccups other than the random rattle - knock knock -rattle of a worn out motor! Yeah I know, if it ain't broke don't fix it lol I figured what harm would it do to just look at the PCM codes if any has shown up in the past few weeks. well low n behold it showed a code in history for the tranny. code 81 - shift 2-3 circuit and the fluke one that keeps popping up for the app sensor.
I just shrugged my shoulders and went to clear them, as the trans has been shifting fine and I didn't think much about it. here's where I should have stopped...
in order to clear the tranny code I had to disconnect the batteries... I pulled the neg cable off each one, opened the door and turned the key on and held the brake pedal for about 30 seconds. I have gotten into a habit of doing that on just about every vehicle I work on... reconnected the batteries and cranked her up. all seemed good as before. rechecked codes to verify they were clear. had to set the clock on the radio too!
Shortly after I was done the wife came out and said hey we gotta go run an errand in town. so we hop in the truck and take off....
here is where things get weird.... as I accelerate slowly down our road I notice a strange sound coming from the engine bay, some kind of hissing. and I'm like WTF now! I broke something lol
we turn onto another road where I can open up the throttle more and I'm thinking to myself what did I do. I should have left it alone. my wife is shaking her head with a sarcastic chuckle as if "here we go again".
this sound is like when you hear someone sucking through a straw as hard as they can. like a major vacuum leak or air pressure blowing out of a small hole. the harder you press the throttle, the harder and more pronounced it is!
I get back to the house, pop the hood and look things over while it's idling. checked the turbo vacuum lines to the solenoid and to the pump as far as i could without digging any tools out. everything looked fine. even popped off the hose from the turbo to see if it had vacuum. all good. looked around both batteries since that was the only thing I touched. nothing...
had my soon to be son n law come out and hold the pedal steady at around 15-1700 rpm while I looked and listened.. all I can find is a rather pronounced hisssssssss coming from the passenger side of the engine. it's loud enough that when driving it drowns out the engine sound in the cab! all I can think of is my vacuum pump justthe bed or I instantly got a massive exhaust leak.
anyone have any ideas?
