ak diesel driver
6.5 driver
do you have a boost gauge?
actually the last time I had my exhaust apart I had started it up with the down pipe removed from the turbo expecting a REALLY loud noise, but it was just as quiet as if I hadn't disconnected it while idling !Oh my God, Big T is going to explode.
Seriously, an exhaust leak will likely have the sound of each cyl. Pull the vac line off the turbo acuator and put your finger on it to see if there is a steady suction on it.
If it wasn't for bad luck, you'd have no luck at all!I was just my luck, I'm sure it was on it's way out, but I shouldn't have even opened the hood!! instead of being dealt an ace of spades I got the joker card from the stack![]()
