Start with code 57. PCM 5 Volt Shorted
Everything else on the 5 Volt circuit is No
broken: Because it doesn't have 5 Volts to it anymore. So the Stupid ECM pukes out a bunch of codes because things are not working. Yeah, but, Shorted 5V is why.
You have several codes for say the APP, Accelerator Pedal Position (APP) 1 Circuit Low , Glow plug relay, boost sensor on the manifold... and they all need a or several 5V reference(s) to work.
You will need to unplug things until the Code 57 is no longer "current" and active. If that doesn't do it you are looking for a shorted wire. Inspect the harness under the intake and the fuel filter assembly.
Check fuses. This means pull every single one out, inspect, clean blades and put back in.
Both batteries disconnected and load tested.
Grounds as mentioned is always a good idea to clean.
