Big T
Do them asap if so. Leaking ones quickly turn into ones that shoot a fine stream. And if that stream shoots through the opening of the precup, it can put a hole in the top of the piston.
I would want to put a volt meter on each of the glow plugs however. It is hard to imagine 20-25 seconds of that much smoke from one or injectors leaking down. Looks like you started truck, walked around, then started recording. In the 5 (?) seconds before the recording as you start it- does one or two of the cylinders not start working? It would be a very noticeable misfire for a few revolutions while the ip fills the lines back up.
New glows and wiring harness. Next step was to replace the injectors. I now have everything to do that job. Wife’s 4Runner is back and medical appointments out of the way. Fishing today and tomorrow. Will tackle the job on Sunday.
