Ferm, what design was the factory 94-95 Suburban? They looked quite a bit different than the trucks. I went ahead and snagged a pair last time I was in the pick and pull yard up near the Idaho farm (3 great pull yards within 40 miles, versus one yard local that is overpriced here in KS, so I hit them whenever I'm out
). Looking on Rockauto if a guy was to buy new they are identical PN, but the factory Harrison units are quite different SUV to truck when comparing, both in thickness and tube routing. The fins are coarser as well, which I think would be beneficial to 6.5L cooling.
I dont know shit about the system designs, but my uneducated thought was it would bump system performance slightly on my crew cab 95 that needs a flush anyways ( bad compressor knocking), so I figured I might swap. I grabbed ythe rubber mounts as well, Im hoping the core supports have the same dimensions on the lower rubber mount retainer so it will drop in with no modding.
