BigDogYJ
So I got the new PSC 6 bolt gear box installed 2 weeks ago. Along with new rare parts pitman and idler arms (removed cognito pitman idler support kit as suggested by rare parts), lower steering shaft, intermediate steering shaft, lower steering column bearing, 2011 hydroboost, and merchant automotive PS lines. I should have done the PSC pump while I was in there but oh well. I’ll get to that eventually.
First of all, dead spot is 100% eliminated got alignment done and it tracks beautifully. My main issue has been getting all the air bled out. It took quite a while, apparently blending the hydroboost systems can take some time. The stock pump started making noise I think I’ve got all the air out but occasionally I hear a little noise from the pump (new PSC pump arrived today). We drove up to the Oregon coast for Labor Day weekend and the truck drove perfectly towing the trailer. So much better than the first time. That dead spot in the steering was not pleasant. Hopefully this PSC box and pump last a good long while. Oh I also bled the system with Swepco 715 fluid per PSC recommendation.
